kindofblue
My backordered hoses finally arrived from TRF. The front ones are straightforward, but I am having trouble with the rears. At the point at which it rests on the trailing arm, there are two fittings and jam nut with a bracket. I loosened the jam nut and can get the fittings loose, but how do they actually come apart. Do you service the inner fitting first. (that being the harder to reach of the two I left it till later.)
Any idead would be appreciated.
Hi Guest!
