walshja
my 1974 has a new brake master cylinder and front calipers, and braking take a lot of foot pressure to stop, I think only the front brakes are working.
the emergency brake was way out of adjustment, barely gripping when fully engaged.
I read up on how to adjust the rear brakes, my question is can I jack up the entire rear of the car? where can I put a floor jack on these cars? if that is possible.
or do I need to use the factory jack, using the holes on the side of the car?
I manually adjusted the emergency cable underneath the car while changing the rear differential last night, and it does grab better, but still not enough, I still need to check the rear brakes, making sure they are adjusted properly.
I have a floor jack, hopefully there is a spot on the car where I can jack up the entire rear of the car, and if not that, at least 1 side at a time without having to use the factory jack.
advice is appreciated.
joe
joe
