After discovering that there was "zero" end float and some slight binding on my rear axles, I proceeded to pull the axles and add the necessary shims to get to the .004 to .006 spec. Since I believe the axle bearings are new, I'd like to be able to check the float on occasion in the future. That raises the question about the need for using the "tab washers" on the bolts that secure the axle flange to the bearing housing that are called for in the parts catalog. It was a real bear getting the old tab washers off. A couple of the tabs that were hard to get to had to be chiseled off. What about using some "new" lock washers on those bolts. Anyone see a safety issue with using lock washers in place of the tab washers?
Rick...
Rick...
