Rear axle rebound buffers
JP_Furble
How are the rebound buffers for the rear axle (thin ones that mount to the top of the frame rails) positioned? Are they centered fore and aft, and side to side on the rail? I've got a Jule frame so must drill & tap these holes myself.
Thanks,
JPF
Thanks,
JPF
Yep that is about the size of it--Keoke-- :laugh:
Thanks,
JPF
Look at Photo #22 in this set.
https://www.mcmaster.com/#threaded-inserts/=cu1ijn
I have a jule frame also and used a lot of these. I got them at Ace Hardware and they are made of zinc coated steel in sizes from 1/4 to half inch. Getting the half inch to compress is tough. But they are holding on my front sway bar and other bits and pieces. I think the rubber pads under the axle are not under much stress so the smaller sizes will work fine.
Jerry
BJ8
bN4
Thanks,
JPF
Check the www.healey6.com website for some other photos for the Insualtion Panels I posted for Jule frame.
Patrick
Jerry
BJ8
bN4
Half my car is held together with those :wink:
Thanks for all the photos! Answered a problem I had with the pan hard rod. Seems the idiot that took the car apart installed the left bracket backwards...
