BN6_2197
Gents, the rear axle of my BN6 is rearing up. I took a look at the plate of the rear axle which is residing on the leaf sping. I observed that the hole of the plate in which centre bolt (toe bolt Moss Part No 725-160) is put is worn out (see attached foto). The hole is curved into the inside.
Any idea to fix the problem apart from changing the complete housing of the rear axle?
By the way: there is no mounting plate (packing piece Moss Pat No 675-445) between the leaf spring and the plate of the real axle in my car.
Volker
Volker
Hi Guest!
