I am repairing a leak in the rear axle and when disassembled the oil seal was pressed into the hub with the lip side against the bearing. Normally an oil seal is pressed in lip side first, which would place the non-lip side against the bearing. What is the correct orientation of the rear axle hub oil seal?
Alan
Alan
Hi Guest!
