64rocksprite
So I tackled the rear brakes tonight. I have all the parts in and new bearings/seals while I'm back there.
Retaining nut came off using a 2" breakerbar with a good push.
I pulled the hub with a 2 arm puller, heard the small 'pop/bang' as it came free and came off without issue. I did have to use the puller almost the whole way to get them off, but with very little effort (this might be relevant below I hope).
Before removing the retaining nut and pulling, I noticed some play in the hub..I could move it back and forth about 1/8 to 1/4"...and noticed the hub was moving OVER the outer bearing race. Bearing still..hub moving. The worry sets in. /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
Hub on bench..I can turn the OUTER race with the hub stationary..uh oh. So I stick a finger through the bearing and behold..I dang near lift it right out of the hub. It didn't come all the way out, but prob 1/2 way. I flipped the hub over and with 3 light taps of the hammer/drift..it was out.
I went back to the axle housing, I can see where the bearing was riding and toward the back, nearest the pumpkin, there is a lip before the 'radiused'area, but the rest looks fine.
Questions (finally..)
1. From everything I know, this hub is junk. I would not think the outer race should spin inside the hub. Right?
2. I see no galling on any surfaces, but if it was well lubricated..perhaps there would be none?
3. Is that lip on the housing a sign of wear or a 'stop' for the bearing? It didn't seem large enough to be a machined stop, my guess is this is wear (lovely..now I need an axle tube) /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
4. Is the root cause of this a lack of proper torque on the retaining nut? I didn't measure the removal torque..but a 2' breaker bar and I leaned on it..it easily could have been close to 140ft/lbs..not that break torque equals make-up I guess.
Just when I think..geez 2-3 more weekends and I'm ready to test-drive! Its been one step forward..two steps back so far. I know, I know, it'll be a better car for it when I'm done. It's just frustrating when that 'to-do' list stays at 20 things...even when you complete 3-4 items/weekend!!
heck, who am I kiddin..I still love the dang thing, I'm just ready to DRIVE it!!
Appreciate the help - thanks in advance!
