Hi all I am not sure how this system works, so when I lube the fitting on the rear axle of a tr3 that is right under the brake drum what would happen if I put too much grease in. Would the extra grease go back into the housing or could the grease move into drum cavity. I believe I put about five pumps from a standard looking hand held grease gun filled with heavy black grease. When I removed the drum there was grease in the drum area. There was no grease on the back side of the shoes only on the front side. No grease got on the shoes, but there was plenty right between the axle and the case also.
steve
steve
