Trying to refill my diff fluid after replacing the pinion seal and having a bear of a time. Using a rubber hose but the fluid doesn't flow too well through it. I found that although the rear axle fluid capacity is fixed, the garage floor fluid capacity is almost limitless.
Any tips that you guys use?
Hi Guest!
