I've had my Midget up on jack stands now for several months as I've been cleaning out the engine bay, repainting some things, rebuilding front suspension, etc. Wheels are off.
Today I was going to reset the timing and reinstall the distributor. So I put it in gear (4th), and went back and turned the rear axle via the brake drum to get it to the valves to the right spot. Except when I turn it, it just spins free - no rotation of the drive shaft. Same on both sides.
Isn't... (and this is where I'm feeling like I'm totally missing something)... isn't the drive shaft supposed to turn when I rotate the rear wheels?
PS
I should add that this car was drive-able before it sat idle. Nothing broken in the drive shaft.
PPS
For some time, I had it on jack stands on two sides of the axle housing, but just had moved it to the attachment point of the front of the leaf springs. Could this have stressed out the axle and caused something to snap?
PS
PPS
