Re: TR3 Bump stops and check straps.
The bump stop is not located under the check strap but beside it. When the car hits a bump the the rubber bump stop contacts the underbody. When the car hits a pot hole the check strap prevents the axle from going down. The check strap is not bent over at an angle but stands straight up and down.
Hi Guest!
