Re: the use of plumbing 0-rings for fuel leak
Steven
Just an update on my leaky Stromberg carbs. They were seeping fuel from the bottom of the carb, and I slipped an 0-ring around the plug on the bottom of both carbs. After 3 months I'm glad to tell everyone that the solution really works. No leaks, no drips, and no carb rebuild just because of a stupid fuel leak. This fix is totally permanent, and it works. Because of some naysayers in this forum, I bought spare 0-rings just in case. Fuel composition does NOT cause these to deteriorate. I pulled them and checked. After 3 months...good as new. Save yourself a few hundred dollars and invest in some 0-rings to seal up the drippy bottoms of your Strombergs.
PC
Congratulations on finding a simple fix.
I'm not entirely surprised that the O-rings you found are compatible with fuel. O-rings are manufactured in massive quantities and sometimes it's cheaper for a manufacturer to make fewer different types in large volumes. It may mean selling some customers higher grade parts than they really need but it still costs the customer less.
Still, I wouldn't feel comfortable installing a non-factory seal unless I was confident that it was compatible. (Mind you, the Stroms on my car are directly over the distrib and starter. A leak means a fire. BTDT.) Your test indicates that the O-rings you got are compatible. The ones on the shelf at the next guy's store may or may not be not be. It was a good idea to keep an eye on them if you weren't sure what they're made of.
On the other hand you can buy the Stromberg plugs, with O-rings, without paying somebody to do a rebuild or buying the whole rebuild kit. As I recall I paid a few bucks each. In my case the plugs needed replacing too, not just the seals. It was money well spent.
PC.
/ubbthreads/images/graemlins/hammer.gif
S
Steven
problem with buying the stromberg plugs is that you have to remove the carbs, and that's a real pain. I'm just glad my solution worked for me...and to let the word out to others that may not want to bother ripping the carbs out. My carbs are over the starter and gas drips find their way close to the exhaust pipe. That's why i wanted to seal it off real fast. If appearance is an issue, the 0-rings can't be seen. Any kind of seal is preferable to some of the inadequate factory tolerances for leaks. I'll keep my eye on it though.
PC
I didn’t have to remove the carbs on my car. I had enough clearence to reach underneath and pop ‘em out. They were almost falling out on their own until I replaced them.
PC.
S
Steven
you must have put your car on a hoist to do it. I can't twist my arms enough to do it from above, and i can't get at it from below. Someday when I get the courage to rebuild the carbs I'll replace everything.
Rick O.
I presume you know that the Strom's are supposed to have an O-ring seated on the base of the bowl plug. If you have just plain old rubber O-rings there, they will get eaten. Viton would be the preferred material.
S
Steven
i don't believe plumbing 0-rings are ever old fashioned rubber because they won't last. Must be some kind of neoprene. I'm not a chemist, and using those 0-rings was a makeshift reaction to a pretty substantial fuel leak I had in the rear carb. I was really happy that it worked out so well. Yes, I'm aware of the 0-ring at the base of the carb plugs. I also know that British made 0-rings are not very good quality, just like brake and clutch master cylinder components. I've read from others on this forum, that leaks around the plugs at the bottom of the carbs are quite common, and a real irritating problem. Hope my solution helps someone else besides just me.....I'm such a generous guy!!!!
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
D TR2/3/3A TR3 "Plumbing"? Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
B Compressor plumbing and accessories Restoration & Tools 11
D The more complicated the plumbing..... Other Cars 6
K TR2/3/3A Judson Supercharger Plumbing Setup for TR3??? Triumph 4
fogliner My HS4 plumbing solution MG 13
B brake servo plumbing for BJ7 Austin Healey 8
Gundy HS4 plumbing Spridgets 6
tony barnhill TPI Plumbing Other Cars 8
69MGC Re-plumbing my B roadster MG 5
sparkydave 1500 coolant plumbing Spridgets 5
frankenstang57 Spitfire spitfire fuel line plumbing? Triumph 7
H BJ7 plumbing bracket Austin Healey 2
mperdue SU carb plumbing - overflow MG 11
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
MGTF1250Dave TR2/3/3A TR3 Brake Plumbing Triumph 5
T TR2/3/3A rings inside bevel Triumph 2
T TR2/3/3A new rings Triumph 12
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
D TR2/3/3A TR3 Headlamp Rings Triumph 8
P For Sale Wheel trim rings Triumph Classifieds 5
R Wanted Whish list: Wheel trim rings and... Triumph Classifieds 9
M TR2/3/3A How many miles to seat piston rings? Triumph 4
cpbol Oil Rings Austin Healey 1
P For Sale O-rings for Smith and Jaeger gauges. Other British Classifieds 2
K TR2/3/3A The chrome rings that go on the face of the guages? Triumph 1
S TR2/3/3A rubber O rings that go around the gauges Triumph 5
HighAltitudeTR3 TR2/3/3A Just rings?! Triumph 17
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
D gapless rings arrived today Austin Healey 1
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
mgedit TR2/3/3A O-Rings for TR3 Gauges Triumph 9
jfarris TR2/3/3A Oversize Rings 83mm Triumph 7
KVH General Tech Installing the Pistons and Rings Triumph 7
K TR2/3/3A Pisto rings again... Triumph 4
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
HealeyDave General Tech Bending tabs on chrome gauge rings Triumph 5
B Kin Pin Kit - O-rings Austin Healey 1
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
Jake OD unit operating piston rings? Austin Healey 1
S TR2/3/3A pistons have 4 rings Triumph 28
oxford piston rings Austin Healey 4
oxford Syncro rings Austin Healey 7
L Instrument O rings and switch plate mounting Austin Healey 4
P Guages with gold rings Spridgets 2
