Hardly seems worth the effort. Trunnions are consumables, so I would just replace it.
I was less than impressed with the quality of a repro trunnion purchased for use on a TR6. The fit was looser than the worn original.
The trunnions came from BPNW. I didn't return them and just used the originals. They are slightly different from the ones used on TR3s.do you recall where that repro came from?
since trunnions wear out anyway, what about having a zerk welded in?
or if my trunnion proves ok.
i may just use a rubber plug until I do replace the whole trunnion.
If it were me, I would try to find a way to install a grease fitting(not weld) on the present trunnion (unless it is grossly worn) until it is time to disassemble and overhaul the front suspension.
Berry
There's a bunch of grease inside the trunnion casting. You might want to consider what happens when it gets heated that hot.
And whether you want to leave the ashes inside the joints.
what's the function of the bottom cylinder of the trunnion, anyway? ...
Berry, you nailed it ( pretty close) I found the old zerk in the corner of garage. I surmise the trunnion was damaged when I had a Jacking accident the other day. I think the zerk was knocked off when the car shifted on the stands.Probably, someone tried to use the trunnion as a jacking point. If the trunnion doesn't appear to worn, I would try to retap the hole (1/4"-28?) or go to an oversize fitting, possibly 1/8" pipe. Also, I was less than impressed with the quality of a repro trunnion purchased for use on a TR6. The fit was looser than the worn original.
Berry
Glad you had success. FYI, there are 2 kinds of zerks. Where I worked, we sold both screw-in and drive-in. To me driving one in would be better than welding. Le
You have to remove almost the entire suspension to get the trunnions out, but it goes fairly quickly. I've done both sides in an afternoon without hurrying.![]()
