R
Rick D
This's got to be kindergarten stuff for a lot of you, but humor me. Got a new generator from Moss, and an included note in the box states that it's been pre-polarized for negative ground applications. My 1600 has the stock positive ground. Included instructions for re-polarizing the unit are: "With both dynamo terminals disconnected, take a length of 14 gauge wire and connect to the hot terminal on the battery. With the free end, "flash" it briefly on to the field (small) terminal on the dynamo. (Just enough to see a small spark). The wiring harness can now be attached and the dynamo should charge." I'm an idiot when it comes to electricity...which battery terminal is the "hot terminal"? -Rick
Hi Guest!
