Re: "Frogeye" Radiator ID Question:
toysrrus
Good Morn`n Boys & Girls,
I had recently purchased a Good, Used Radiator to install in my `59 Frogeye (I like the way Frogeye sounds over "Bugeye").
Anyways; On the top of the Rad. It has an "ID Plate" that I have never seen before. It measures approx. 1/2"w x 2"lg (Brass of Course). The markings read: (ARA 92 41 61).
What do the markings mean? Is this in fact an Orig. "Frogeye" Radiator?
Thanx for Your replies,
Russ
The original radiator on my 58 (no shroud) had that brass plate and the letters were ARA only one number legible and it was a 1. So I would assume yours is an original.
Hi There jm,
"Thanx" for your input. Where in SC do you live?
Regards, Russ
Ara 92 28 63 on the one I have which I am certain is an original...as to what the numbers mean...I hope someone chimes in with more knowledge!!
I always thought the last number was the year of manufacture.
But I do know the tops of the radiators changed from the Bugeyes to the MKII Sprites. 4 ribs to 3 at some point but I am not certain when that change took place.
The radiator that is original to AN5L 9382 produced January 1, 1959 has a brass plate that reads as follows:
Manufactured By
Morris Motors, Ltd.
Radiator Branch
Osberton Works, Oxford
ARA 093 10 00008
Odd that it reads 093 rather than 092. I suspect that the 10 is October and that the 0008 is 1958.
Hi There Spritenut,
Thats what I would think but that theory was killed by "bugimike" being certain he has an "Orig" Rad to his `59 BE since his Rad reads ARA 92 28 63.
I guess its back to the archives & see what some books have to say.
Thanx, Russ
PS: Mine is boiled out, checked out, painted etc & Is "Good to Go"!
