When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
I bet 1100 lbs for an empty body is high - shell is 300-350 lbs. racing seats? dash - 15 lbs? wiring 5 lbs? I know shocks and steering etc factor in but....
Gotta cut out and lay in new heavier frame ans suspension stuff. You didn't think I was just gonna shove in a V8 and run 11.XX's with a stock frame and suspension...did ya?
I might be low budget but that doesn't mean I'm stupid.
I'm still up in the air. The Midget I have is solid, the Spit has rusty rockers, quarters and rear frame (That I'd cut out anyway)and the 6 I have is solid w/ a rebuilt front end. While Midget would be truer to what I want, the Spit wouldn't be a sacrifice and the 6 is an all together a different build.
