Radiator Temp Gauge
T
Twstnshout
Member
Is there an easy way to adapt the modern temp gauge male threaded fitting to the backward female treaded temp sender radiator fitting?
The only way I see is to cut the old fitting off and braze or solder a modern piece onto it to tread a Bosch temp gauge sender into it.
