nevets
I read a bunch of prior posts on this subject, which were very informative with some creative solutions. Just installed an aftermarket radiator expansion tank. I believe I followed all the requirements concerning venting, partially pre-filling the tank, tube configuration, etc. I think it's working, but I'm not sure. My question is this: Is it necessary for there to be a solid column of coolant in the tube to the tank? I'm pretty sure the answer is no, but I thought I would see what others have to say. Thanks
picture shows the setup. It's a little dark but if you look carefully, you can see an air gap in the column of coolant in the clear plastic tube.
