Radiator Flushing
TR6Stu
Most manual diagrams show a drain plug at the bottom drivers side of the radiator.
Our 74'doesn't seem to have one.
Does anyone else have this?
DougF
I've found that the easiest way to drain the rad is to pull the bottom hose on the engine side. The drain plugs are usually corroded enough to make it nearly impossible to open them without damaging something.
T
TR6Stu
Original? Not sure.
Manual lies, never a more true statement.
Thanks DougF, bottom hose as you say is probably the best method.
TR674
Billspit
a friend of mine has a Hotrod and had the same problems due to very infrequent use. He installed an inline silt filter into the top radiator hose. This unit is stainless steel with a filter which catches all the loose scale and silt. It must be cleaned regularly (he does his every time he runs the car). Since installation he has had no more trouble with over heating. I believe they can be bought from most auto outlets for around $50, just a thought.
Regards
Craig
mrstinson Flushing Radiator and Replacing Hoses --- Suggest? Spridgets 7
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
D BT7 radiator Austin Healey 1
M Radiator Paint Austin Healey 20
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
