Nelson
I am near the point in my restoration where I need to add coolant to my radiator. The engine is newly rebuilt so I am starting with an empty system. Is there something that is better than the 50/50 water and Prestone that I used many years ago when the engine was last run? Is tap water OK to use or should I consider using something like distilled water or the stuff run through reverse osmosis at my local supermarket? Living in Ohio I have to take winter temperatures into consideration.
