Radiating and cooling!
Platinum
Am in the "middle" of flushing the cooling system on SWMBO's MGB. First step was force-flush the block and the rad with the garden hose (Also "hers"-- another story). Thermostat housing off, t-stat out and full pressure thru the block and heater core. Plenty of 'dark matter' out of both. Same with the rad. This is a "three-core" we had done back in '96 or so.
Step next: drain all and reassemble. "Where's those gasket sets?!" --- Not a t-stat gasket to be found. *mumble-mumble*
Take time to clean the t-stat housing surfaces and fab a gasket from raw material, assemble all, pour in some "GUNK" rad flush stuff and top it off with water. Starts like it was run yesterday (sat two weeks since last light-off), takes a while to get up to temp. Me sittin' in, reminiscin' about the miles wut have passed under me butt in MGB's...
Now waiting a bit to let 'er cool so's I can drain and flush it out again with the hose before I put the coolant mix in. I would rather flush it with "fresh" water once more than just drain it and toss the coolant in there. The second flushing will carry away or dilute what residual chemistry there may be left in the system. Just precautionary on my part, but that's the way I am.
Second flush, find fan belt is a teensy bit too long... waterpump may not have been as efficient as it should be. Search th' hovel, find a more appropriate belt... now running third cycle "for effect". Bloody BORING!!!
...but it makes such lovely sounds. Wish I had a way to make a .wav file...
I always like to flush twice. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
"If its yellow,
let it mellow
If its brown,
flush it down."
and if it burns beware of the bore punch... Or at least that's what i've been told!
Thread degerates quickly into base bathroom humor...
You guys are so sophomoric. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Not like ME... I try to set a good example and this is what happens.
MWUHAAHAAHAAAA!!!!!!1!
...anybody want a noice lookin' bridge?
's orange. Kinda long and it's out in Kalifornia. I'm a motivated seller, let it go cheap... /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
heh
riiiiiiight...
and I have a '88 Lotus Esprit Turbo in me driveway... /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
