Has anyone experienced this? Is there a cure? I figure they might be a little wavy or have some grit between them even though I cleaned thoroughly before re-installing. Why not use 1 solid shim? I can cut one on the waterjet at work and not have to deal with all the pcs.
Would this be OK or is there a reason for multiple shims. There's gotta be a dozen or so.
