skelly
I bought my '64 Sprite a couple of weeks ago and noticed the coolant temp got a bit high (195) on an extended drive. At the same time my oil pressure dropped fairly low (under 20). I installed a summer thermostat rated at 160 degrees to bring the temp down. The thermostat that came out was a 180 degree one. After installing the summer thermostat the gauge now reads 180 degrees after warm-up . Is it possible for the water temp gauge to read 20 degrees high? BTW, I changed the oil to Valvoline VR-1 20W-50 and my oil pressure stays at or above 40. Can the water temp gauge be calibrated? Thanks for the help.
