wkilleffer
Hi everyone,
About a year ago, someone on the forum mentioned that you could simplify your adjustment of the valves by getting each valve into the proper position as directed by a manual, opening the lock nut, turning the screw until it was all the way tight, then back it off 1/2 a turn.
Does that sound familiar to anyone?
I've never been satisfied with my valve adjustments. They always seem too quiet and tight, or too loose and noisy. Anything that could make this easier and closer to foolproof would be great.
Also, I've installed a Flamethrower dizzy and coil into the car, which has an 18GK engine and HS4 carbs. The factory timing spec makes the car seem a bit sluggish. But I don't want to go too advanced and cause pinging or hot running. That I know of, it's not pinged. But it seems to run in the right half of the temp gauge if I have to drive at speeds exceeding 55 mph. The car lacks overdrive as well.
Any advice or suggestions would be appreciated.
Thank you,
-Bill
Thank you,
-Bill
