RJS
OK, some of you may have just seen my post titled "Calling all TR4A's". Fortunately, I solved an oil leak issue caused by an under-qualified "British mechanic with 30 years experience".
Ugh, I need to vent.
Over the past 10 years I have been forced to take-on more of my own work on my Triumph because of lousy mechanics. Fortunately, I really enjoying learning and working on my car. It's a great aspect to the hobby. But, if I may, let me list the "issues" I experienced:
1. PCV valve fitted incorrectly leading to crankcase pressurization and huge oil leaks
2. While bleeding the brakes, spilling brake fluid all over my fire wall and battery box..subsequently eating all the paint off
3. Installing incorrect size u-joint on drive shaft. Result, dropping my drive shaft on the Merritt Parkway at 65 mph!
4. Adjusting my carbs sooo rich that I suffered a hot start problem for about a year (it was like having the choke on all the time). The excessive cranking led me to kill:
a. starter
b. battery
c. starter solenoid
Oh, then there's the constantly trying to sell me new parts I don't need. Typical call: "I have your front brake calipers here on my bench. The pistons are all frozen. I can have new ones here by tomorrow and installed for $250 each plus labor". What?! I brought the car in for a routine service and oil change. The brakes are fine, put them back in! Four years later, brakes are still just fine.
Anyway, the past few years I have taken on almost all service and maintenance myself. I find that I really enjoy it, know it's done right and save money. Triple bonus.
I have to say thanks to BCF and thanks to all you guys (and gals) for your great advice when I am tackling an new issue. It has really helped me solve a lot of issues and enjoy my car even more.
a. starter
b. battery
c. starter solenoid
Back around 1971, I was a poor college student sharing a three-year-old Mk3 Spitfire with my dad. As the result of a particularly bad experience at one of the local Triumph dealer "service" departments (they supposedly replaced the "bent jets" in the carbs and a few other things...none of which solved a problem that turned out to be a failing coil!), I went into the parts department and purchased the Workshop Manual in the display case and set out to learn how to do as much as I possibly could myself. It has paid off rather well in the nearly 40 years since! After that bad experience, I only ever went to a Triumph dealer service department (different dealer) two other times, both for jobs that required specialized tools I didn't have and couldn't afford. Thankfully, both of those experiences were a bit better, but that was mostly due to intervention on the part of the parts department manager (same guy that had been at the other dealer before), with whom I'd become good friends!
