Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Umm OK,
You can suck on the unit to see if it moves, but this does not tell the whole story. These units require a particular amount of vacuum to advance a certain number of degrees. So you might want to test the unit once the car is running to see if it is giving you the right amount of advance when the engine is creating vacuum.
Sucking on it lets you know if its at least working...then you can go from there...if it doesn't move when you suck on it, you've got other issues to solve before putting it on the car.
Right Tony,
That's what I was trying to say. Sucking on it (to see if it moves) lets you know it is not totally shot, but once the car is running you will need to test it further to make sure it will work with your engine.
Ah, so. I knew they had USAF types at Custer, and Kellogg was, and still is, home to a FANG unit. The first time I was there, they were flying F-89J's, then B-57's. Now they're herding A-10's.
Jeff
Jack, I think the only pic that was ever posted of my car, was the infamous low level snap roll in the Bugeye. I don't even know if it's still around. The Bugeye, is, but I don't know about the picture.
Jeff
Oh, I had plenty of altitude, after the first impact with the ground. Kind of bounced about twenty feet, straight up!
But, it was still too low to punch out.
Jeff
Second pic link is up.
It's funny, but after I was back in the pit, waiting for the car to be brought back, this cute young thing walked up to me absolutely sobbing. She threw her arms around my neck and blubbered "It.... was..... such.... a ....pretty ....car."
Don't know who she was, and never saw her again!
Drat!
