twas_brillig
What is the collective wisdom on quarter elliptic rear springs?
I pulled ours a few years back and found a couple of broken leaves plus a couple of the 'clamps' holding the leaves together were also broken. I ordered replacement springs and reinstalled. The replacement springs cause the car to sit higher than it should but I haven't got 'round tuit to pull them again and get them re-arched.
- is it possible to replace just one or two broken leaves?
- owners of old Model A Fords apparently have been known to insert teflon between the leaves of their springs; any benefit to doing something similar for a Bug-Eye?
- if the spring is out and going back in, is there any particular lubricants or other products that the springs should be soaked in?
Thanks,
Doug
Thanks,
Doug
