Jimflorida
I am cleaning up the gauges that came in a box for my Bugeye. On the back of the gauge body for the tach are three holes. The center hole is for the tach cable. One hole has a plastic cylindrical piece that sticks out about an inch out the back. Not sure what this is. There is another hole about this same size. I also have a bulb holder that goes in one of these holes. If this bulb holder goes in the open hole (that does not have the plastic bit in it, it seems to sit right behind the ignition indicator on the face of the gauge. So, the plastic bit must hold some type of illumination for the lighting. Is this correct?
Also, I am planning on probably just keeping the stock generator, as I am not going to run any fancy electronics. This way, I can just keep the mechanical tach. correct? Any disadvantages of sticking with this? Jim
