Triumph Valves have a diaphragm? All the ones I have seen are just a plunger with a spring. When the intake has a lot of vacuum ( at idle or overun), then the vacuum overcomes the spring and closes the valve. There is a small built in leak when the valve is closed. When the engine has low vacuum under acceleration, the spring opens the valve wide open so all blowby goes to the intake without restriction. A valve like this would stick, either open...which would make a fast idle due to the vacuum leak, or stick closed and the engine would pressurize and blow oil.
If there is a diaphragm, then the failure would have to be wide open...resulting in a vacuum leak and fast idle. If you tried to reset the idle, then the mixture would not be right, no matter how hard you tried. Then you would have a rough, rolling idle.
