jlaird
I am unable to get a plunger for the tranny 1st 2ed fork rod out. It seeingly has a bad burr on the bottom by all indications.
This plunger is steel. Any reason I can not drill a small hole down in it and use a tap to pull it? The plunger is at least 3/8 in long.
I have bent steel rods to push from the bottome of the fork hole but can not get a long enough right angle in there to push it all the way up.
