I don't know about the 75 having flat tops (haven't taken my '75 engine from Mark apart yet), but I know for absolute certainty that 76's had them. With 9:1 you can run 87 octane stock, I did when I first got the car. I wouldn't do any major performance mods and try to keep running 87, though. The timing's pretty retarded with the stock settings, so you'd probably do the engine good to advance it a bit. Mine's advanced to something like 16 degrees at idle ... I digress ... at any rate, flat tops will give you better performance, and I doubt you need to change octane with stock ignition settings. The change from 10.5 (what I've currently got) to 13 would make a neglible difference, but from 7.5-9 is a significant improvement (law of diminishing returns). Just install everything on the car and don't worry about the pistons. /ubbthreads/images/graemlins/smile.gif The dish (in my opinion) isn't desireable, mostly for the lower compression ratio. They say it promotes better combustion, but I'd wager it's mostly negligible. As to turbulence, there's already an enormous amount from the piston thrashing about and the valves slamming open and shut at a ferocious rate!
