I did a search of this forum, but was unable to find info on the front body mounting. On the front diagonal tubes, there are rubber body pads (two per bolt), aluminum body mount pads (one per bolt), and an inner fender mount plate. My question (as I forgot what was there when I took it apart
) - does the steel fender mount plate go on top of the body flange, and the aluminum body pad (sandwiched with a rubber washer on top and bottom) go between the body flange and the frame?
Stu Boyd TS78330-L
Stu Boyd TS78330-L
Hi Guest!
