MGB Question on timing and vacuum
drooartz
Funny how things leave your memory after too many years. I need to check the timing on my 70 MGB, and can't remember if I need to check that with the vacuum line from the carbs to the distributor in place or with it removed and plugged. Been too many years since I tuned this car, and my Morris Minor has no vacuum line.
I have vague memories of removing and plugging that line with a golf tee for some tuning task, but can't remember why. 🤪
Platinum
Disconnect it. And find that tee... 😉
drooartz
drooartz
I think it's still in my toolbox. ⛳
drooartz
drooartz
I need to look this up, but I seem to remember setting it to 32* at about 3500 rpm, so with all the mechanical advance in. Does that sound about right?
Platinum
Just like the Island of Misfit Toys, some of the things so anachronistic to their original purpose NEED to be at hand when no other "thing" is available.
A couple of 1/2" wood dowels can isolate a leaking heater core. Emery boards can clean a set of points.
As long as the dizzy is operating as it's supposed to. Did Jeff supply the dizzy?
Platinum
That's how mine is set, but I don't have vacuum advance.....mechanical advance only (DCOE carb)
I kept the vacuum advance even with a 40 DCOE, but set the timing with it unconnected.
drooartz
drooartz
Jeff did the dizzy a few years and not many miles ago so that's in good shape.
I have a drawer of misfit tools like this. my grandfather was a piano tuner, and he had all sorts of made-to-suit tools. Guess I inherited that too.
drooartz
drooartz
Yup I have an entire little drawer of golf tees. :smile:
Also found my old notes for the car. I bought this car for the first time in 2011 (then sold it to my friend Paul, then bought it back from him) and I kept good notes in a little notebook. The notebook stayed with the car, so I could go back and see what I did in former tuneups. Back when I first owned the car I also made a little card with basic tuneup specs that was also still in there. Sure enough, I used to set the timing at 32* at 3500 RPM.
I'm glad I checked now, as the car is set quite a bit more advanced -- hopefully explains why it hasn't felt or sounded quite right. I'll get it reset once I can corral my helper again. I curse the engine designer that put the timing marks on the bottom of the engine. Really should get one of those kits to make a pointer on the top somewhere. Ah well, my wife's well skilled at watching me lie on the ground and lift my leg to let her know when to run the engine up. Should be able to get back to it this weekend and get the timing reset.
Plugs were the type I expected, and gaps were set pretty much on (tweaked a couple but probably just OCD to get them spot on). From a quick plug read it looks like I have the mixture set reasonably.
Platinum
Great that you kept a logbook! I know what it's like to try to recall what was done to which car and when, without one. 👍
As for tees, I'm obviously remiss in my restocking duties. This bin of bits was sat on my bench when a water heater line let go, it wasn't the most important thing there to quickly get removed, but the only drawer to get water in it was this one. BTW, this little cabinet is only slightly younger than I am.
drooartz
drooartz
I'm so glad I did -- nice to be able to see what's been done, as the good Lord knows I won't remember! I thank my 11-years-ago self for writing this stuff down. I've got scattered notes on the Morris as well, need to get them written down into a notebook one of these days.
My cabinet's a youngin, maybe only 18 yrs old. I'm no golfer, but I did do a vendor golf outing a number of years ago and kept the tees -- specifically for old car work. Priorities you know.
D Cam Timing question. Spridgets 11
Lin Ignition timing question Spridgets 2
P TR6 1970 TR6 Timing Question Triumph 2
B Timing Light question Austin Healey 0
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
BillyB62 TR2/3/3A TR3 timing/distributor question Triumph 7
G TR4/4A Timing and Distributor Bushing Question Triumph 7
Q TR2/3/3A Valve Timing Question!! Triumph 5
Randy Harris Timing is everything - the question is - is this the time? Austin Healey 14
R Question on establishing a baseline timing setting Triumph 3
L Timing question Spridgets 9
TR4A_IRS Pertonix Timing Question Triumph 4
D BT7 Timing mark and pointer question Austin Healey 6
W TR6 TR6 Timing chain oil seal question Triumph 3
Pythias Timing Question. Spridgets 4
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
davidk TIming Question Triumph 3
RedTR3 TR2/3/3A TR3 Timing Question Triumph 3
veale001 TR6 TR6 TIMING QUESTION............................... Triumph 35
T A quicky timing question Triumph 2
PAUL161 Question on Cam Timing. MG 5
poolboy Lucas Dizzy with micro timing adjustment question Triumph 20
M Another Ignition Timing Question Austin Healey 8
J Timing Question MG 0
T Final Timing Question [I hope] Triumph 10
T Another Timing Question Triumph 18
Bruce_B Timing gear on camshaft sprocket question Spridgets 7
John Loftus Timing chain tensioner question Austin Healey 14
Tinkerman TR2/3/3A 60 TR-3 Post 60000 Timing Chain Question Triumph 1
10musketeer Too Retarded? [Remedial Timing Question] Spridgets 14
R Strobe Light Timing Question Austin Healey 2
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
SilentUnicorn 1275 timing chain question Spridgets 2
txtr3 basic ignition timing question Triumph 3
sultanoswing Timing Light Question MG 4
sparkydave Timing and temperature question Spridgets 7
6 Big Healey Timing Question Austin Healey 6
Bret Timing Lights & Hot Coils question Restoration & Tools 3
P Timing Question Austin Healey 5
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
