I ordered the Moss thin belt/damper conversion kit p/n 837-508 and in it is a spacer p/n TT11322. This spacer is to be pressed onto the back of the damper pulley and acts as the extension that goes into the timing chain cover on which the front seal presses to keep oil from leaking out the front of the engine. The spacer received in this kit is not smooth as I expected, since the original type pulley hub is very smooth. The spacer in the kit has a machined surface that has VERY SMALL groves going around the spacer on concentric circles, i.e. not spiral. The question I have is will these grooves cause a problem by causing deterioration of the rubber front timing chain cover seal due to the friction of the grooves?
Regards,
Regards,
