General MG Question on selling
jackq
I've had numerous Mgs for many years and the time has come to liquidate everything I have. I've owned a VW resto shop and have been able to do well with those but selling the MG hoard has been difficult. I've come to the decision that it may be a better idea to part them out as people seem to want to repair or build there own vehicles. A coupe, B roadsters, BGT, CGT and a 77 B roadster Rover V-8 5 speed conversion. That one has less than 1000 miles since the rebuild. It may sound heartless but it's strictly me being practical. I'm planning g ahead. When something happens to me I don't want this mess dumped on my family. If anyone has any other options (other than Craigslist or E_Bay) please feel free. Thx.
Stewart
Bring a trailer especially this time or year might be a good option. Take lots of pics of the good bad and ugly and invest some time to answer the questions in the comment section during the auction. MG's seem to do well there especially when well presented.
Rut
Jack,
Im in the same boat and I’m in the process of deciding what needs to go and what won’t be a pita to my family when I’m gone. The BAT suggestion is a good one and I plan on selling there as well. Cars that are presented with the good, bad and ugly along with pictures and seller comments to specific questions do really well.
Rut
JPSmit
Jack, as above. I think parting out will be a PITA - and will ultimately take longer. At this point keep in mind that the goal here is not the biggest dollar or the best home but the emptiest shop.
cheers
jackq
jackq
I understand the PITA factor. But if I just pull the drivetrain and things like the new wheels and tires, w/s assy, instruments..and only big chunks like front end and all the kites. Then scrap the body, I won't have a hulk lying around.
YakkoWarner
Another thing to consider is that the bodies themselves may be valuable - I had a complete car with a really bad body. It took me quite a while to find someone selling a solid rolling shell that I can transplant the remainder of my otherwise complete B into. I still have to replace the floors, but otherwise the "new" body is solid. The body is often the hardest thing to find in usable condistion...
Shealey Question about vendors thinking bout selling stuff Spridgets 3
jaybird Question about selling a LBC MG 13
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
