Question on rebuilding Stromberg carb
ScottFromNH
Hi Guys.
I have a question. I have a 1973 Spitfire 1500 running a single stromberg carb. I am getting ready to rebuild it as the car was sitting for the last 10 years and think it really needs it.
Besides the rebuild kit I am getting from VictoriaBritish website is their anything else I should be replacing at that time. Not sure about the needle valves and stuff like that since I am already in the carb to rebuild it?
Any suggestions would be awesome
thanks
scott
Brosky
Fuel filter and it wouldn't hurt to pull the fuel pump off and take it apart to clean what is surely dried up and ready to flow to the filter or newly rebuilt carb if it is unfiltered.
Of course you would want to get the tank cleaned out was also so you don't undo all of your efforts up front.
ArcticOne
May not hurt to get a backup needle, just in case.
And find out where in your town you can get o-rings at. Although the rebuild kit has them (and lots of them for various carbs) I found that I needed to get one locally as its easy to damage them.
jb
70herald
Take the carb apart before you order the kit and see what kind / level of wear and tear there is. if the butterfly doesn't close fully or the throttle shaft is worn, you are looking at a much bigger job than just replacing the rubber bits.
S
ScottFromNH
Hey Guys thanks for all the input.
I have already changed the fuel filter, fuel pump and cleaned and resealed the gas tank.
The car actually runs pretty decent the only reason I am thinking it needs the car rebuilt is that when I fill up the damper with oil it only stays in their maybe a day and then its empty again so I am guessing that the diaphragm is dry rotted?
I will look at picking up a new needle valve at the same time since I am already in there I would like to just have to do this once. and also see if I have a local store around that does o-rings.
70herald
A damaged diaphram will cause the car to stop running or if only a small tear it will run erratically, so that is not your problem. I suspect that you just expect to see more oil in the top of the carb than is supposed to be there. It only needs a few drops. Any more and it just gets pushed out.
S
ScottFromNH
oh I didnt realize that. Thanks for the heads up maybe I dont need to rebuild it. Is there any good test that I can do to determine if it needs to rebuild or just run it and see how it goes?
Brosky
It looks like it's time for another trip to the Buckeye World of Carb Rebuilding.............look down this list until you see carb rebuilding parts I, II, III and download the pdf files.
Buckeye Technical Data
sail
Thats good information. Armed with that rebuild kits usually come with one page instructions which run you through the steps.
tdskip
If you do get a rebuilt kit make sure to get the bypass diaphragm replacement - it is often missed. Not sure if the VB kit includes them.
If the oil is being sucked that fast, the O-ring in the needle adjustment screw is likely FUBAR. That's the only point where it could be sucked thru as described.
70herald
Forgot about that o-ring, I have one of the non-emissions controlled carbs. even fewer parts to worry about. Just don't stand behind my car when I pull the manually controlled choke :devilgrin:
:lol:
S
ScottFromNH
Hmmm now that makes me think I should.
Ok I guess I wonder what the opinions of others are. Would you rebuild the carb or just run it like it is?
The car starts and runs, the manual choke seems to work good and I can shut the choke completely off and the car seems to idle good. I haven't been able to drive it yet as it is a Fred Flintstones car right now (floor boards are gone)
the car did sit for 10 years in a shed that was only 3 sided so the elements have gotten to it.
Right now the car is up on blocks having the sheet metal fixed and I have a set of headers coming in to get rid of the broken exhaust manifold. I really dont mind spending the 100 bucks to rebuild the carb if it needs it, however I dont want to make things work.
This is my first restoration so I guess I am just too new to know with out asking
sail
Well, it does run and if it doesn't leak sounds like you have plenty of other stuff to do.
If it has sat for that long, it'd be the right thing to do to rebuild the carb. Just take your time and if you run into a snag there's usually someone here to answer any questions fairly quickly.
70herald
If the car sat for 10 years you are going to need a new diaphragm in the near future one way or the other.
Likewise the O-rings are going to be dried out and probably leak in the near future, especially with todays nasty stuff in the gas.
Since the engine is currently running, I recommend that you take out the carb, give it a good looking over, replace the gaskets, o-rings etc and put it back. <span style="text-decoration: underline">DO NOT touch anything else on the engine!</span> you don't want to put the carb back in, have a problem and then start wondering if it is the carb, distributor, fuel pump, flux capacitor, or whatever else.
S
ScottFromNH
Thanks for all the input guys. I am just going bite the bullet and buy the rebuild kit with a needle valve(maybe a gross jet instead) and rebuild the car now that I have it in the garage so that when the car is done I don't have to worry about it.
Brosky
I don't think that you'll get much support here on the Grose jet. I could be wrong, but let's see what happens.
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
RedTR3 TR2/3/3A Rebuilding TR3 Fuel Pump question Triumph 5
JPSmit Today's question -rebuilding Spridgets 0
J Master Cylinder Rebuilding Question Spridgets 3
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
