TR2/3/3A Question on paper air filters for TR3
TuffTR250
I'm still thinking of putting paper air filters on my TR3. I have found some Baldwin air filters that are quite small but that I think would work on a TR3. See pictures below. I would have to fabricate some front and rear plates to hold the filters. I measured the old steel mesh air breathers and I counted 8 inlets around the filter, each being 1 inch x 1-1/2 inch, which gives an inlet surface area of 12 square inches. The Baldwin filters have a paper inlet that is 3/4 inch wide and the circumference is 16 inches which gives 12 square inches of inlet surface area also. My question then is...would I get as much air flow with 12 square inches of paper air filter as with 12 square inches of the stock steel mesh filter? Thanks!
Regards,
TR3driver
Great Pumpkin - R.I.P
My _guess_ is that the paper filter element is more restrictive than the original rock catcher, even after taking into account that the paper is pleated (and so has a lot more surface area than just the perimeter of the filter).
If you are going to fabricate plates anyway, why not use TR6 filter elements? You'd have to offset them from center (as the original filters are), but there is plenty of room for them.
T
TuffTR250
I thought the TR6 filters would be too big. I did not try them. If I offset TR6 filters, will they fit without swinging the float bowl over like in the picture of the TR4A oval filters you posted a picture of a while back? I prefer to not have the float bowl swung over. Thanks!
Regards,
TR3driver
I believe they will fit, by offsetting them up and to the rear. But I haven't actually tried it, so I could be mistaken.
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
K TR2/3/3A TR-3B carb question Triumph 13
