77MidgetMkIV
Hello all,
I am trying to track down a problem in my system that is knocking out my tach, fuel gauges as well as turn signals and wipers. On advice from here, I have checked every connection in the fascia wiring harness, I have cleaned the fuse block and cleaned all grounding points that I could find on the vehicle. I am now thinking that it might be the voltage regulator, but am not sure how to test the unit. According to the wiring diagram, the double lead connecting to the V.R. goes to the fuse block and the hand brake switch, and the single lead goes to the fuel gauge. Questions:
1. Am I correct, then, in assuming that all of these accessories are wired in series (still not that good in reading the diagram) meaning that the problem could be anywhere?
2. What is the best way to test the V.R.?
3. Any other points/connections/hints? Other than a couple orphaned wires for a now gone stereo system, everything seems to be original, and the only connection that seemed suspect was a slightly damaged brown wire listed as part of the ignition system in one of the connectors under/behind the steering wheel, but the ignition circuit functions fine.
any advice/thoughts would be appreciated, as I am far far far from being considered a wiring guru.
thx
markfitz
thx
markfitz
