jlaird
Did you know that the brake pedals have brass inserts where they swing on the bolt at the master cylinder box. No that is not the question but when was the last time you put a drop of oil there, it does not seem to be in the factory maintenance book, gesh.
Now for the reall question. One of the pedals has a stop welded to it about an inch or so long, is this clutch or brake or have you noticed??
