Question about wheels.
William
Hey-Dad's car is a '71, with Rostyle wheels. We had a flat earlier this summer, which we were told was because the innertube stem had blown. The reason we had a tube was because the rim of the wheel is rusty and does not seal properly. The shop cleaned it up a bit and put the tire on and everything was just fine till last weekend. Same wheel, flat. We're getting a correctly sized tire put on the spare wheel (I posted about that!), and hopefully can get the flat tire reseated and aired up. But, is there a way to keep these sorts of things from happening? It's not like the tire was a bit flat and we watched it slowly deflate, it was fine, then pffffft! No air.
-William
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by William:
Hey-Dad's car is a '71, with Rostyle wheels. We had a flat earlier this summer, which we were told was because the innertube stem had blown. But, is there a way to keep these sorts of things from happening?
-William
<hr></blockquote>
Put a tube in it. There are plastic grommet/stem protectors available to install in the wheel stem hole so that the stem doesn't get damaged.
Actually, we found out that the tire bead was cracked, and had finally let go in a big enough way to deflate the tire fully. We had the "Crazy Oversized Spare" replaced as well, so we now have a matched set of five.
Dave-the tire originally had a tube, but everything I've read has said that Rostyles should not be used with tubes, unless the tires specifically call for it. I could be wrong, after all I did read it in a magazine.
-William
