19_again
Hard to believe, but I have an electrical problem. When I use my lights, my ignition light comes on regardless of rpms. I'm postive ground, have reversed polarity on my generator. I think I can drive the car for days without using lights and my battery will be fine. But using lights for 30 minutes will kill the battery. The car will run until I shut it off, but will barely turn over when I try to start it, eventually not cranking at all. DPO had hand wound the wires to the headlights at a break point (as opposed to solder, crimp, or even tape). Since I have new harness on order, I just coated the joint with dielectric grease and taped it up good. As expected when I first start the car, after releasing choke I'll see the ignition light for a few seconds until rpms even out. After the battery died last time, I reversed the polarity on the generator again per instructions forwarded by Jack. Tonight it happened again after 30 minutes of lights on. New Generator/ new battery 1 month/new battery cables.
Any ideas?
Any ideas?
