crj7driver
I am thinking about picking up a positive pressure air mask for painting and welding when you can't remove the paint from the hidden area of the weld. It might be overkill as I am not painting anything worse than POR15, which is definitely not finger paint. I always set up fans in my garage and wear a canister respirator when I use this stuff.
I know I am being overly neurotic but I was just wondering what I need to use pressurized air. I want something for occasional use.
I have a normal oilless 35 gallon husky compressor that I may use. So what is the easiest SAFE way to go? When I looked at a couple of filters that were designed to run off air compressors and breathed they were $5000. Perhaps an oxygen bottle with regulator? Can I use just an inline filter, perhaps with a water bath?
Thanks for any advice.
Hi Guest!
