TexasSprite
Is there a table anywhere that expains what is involved in combining engines and gearboxes? I have a 59 BE, so if I replace my smoothcase gearbox with a ribcase and keep my 948 engine, which other style parts do I use? (release bearing, slave cylinder and the shaft that the release bearing rides on). The guy who rebuilt the ribcase transmission actually drilled and mounted a front cover from a smoothcase in my ribcase rebuilt. I am assuming that there must be a difference in the position of the release bearing pivot between the two models. Given the modification he made, I am assuming the transmission looks just like a smoothcase to the engine and all the stock 948 parts will work.
In the future, if I wanted to put a 1275 in place of the 948, what would be the correct set of parts for that configuration?
One last question: The BE MC has a 7/8" bore. Is that a problem with using a later model ribcase?
I think I can see all the variables, but just don't know how they interrelate to cause problems.
I'd hate to go though all the work of pulling the engine and finding our after it is reinstalled that I used a wrong combination of parts. Pulling it multiple times is even a worse nightmare!
Thanks for the help!
