TR4/4A Question about cleaning instrument faces
rnpennington
Now, I was able to twist the chrome bezels from the instruments to remove them so I could polish them and clean the glass. After I took the bezels off, there is a lot of black crud on the inside of each bezel. It looks like a deteriorated rubber ring or something. I assume it is some type of sealing ring or substance.
Can someone tell me what this is?
toysrrus
Hi Bob,
Typ. they are "O Rings" that do seal out moisture etc.
Take a look in Moss`s Cat or VB & You`ll see them spelled out for you for all your Instruments.
Regards, Russ
charleyf
The O rings are on the outside of the gauge. Inside there is some sort of a substance that has hardened and usually cracked. I believe it was to seal the bezel to the glass. It is preferable to put something in there to help as a spacer / seal. I have used an old O ring in there but recall that I had to cut it to make it smaller to fit inside.
Charley
glemon
Although, agree with where the discussion has gone above, re the seals, I will add that, though you didn't say anything about it in your post, your topic line says "cleaning instrument faces" if you are planning on doing this do it very gently, as it is easy to do more harm than good, I usually just gently wipe if with a soft damp rag, like eyeglass lens or tablet screen cloth. Sometimes I don't even go that far, just give them a very gentle dry dusting.
dklawson
As above, limit the gauge face cleaning. Use no solvents or cleaners other than water and blot, don't rub. Cotton swabs are handy.
I typically take the chrome bezels with the goo on the back and soak them for a day or two in those gallon buckets of "dip" carb cleaner. Once fully softened you can pick the material out and eventually expose the hidden chrome. You can buy replacement seals from some places. The DIY fix I use is to go to the home center and buy various sizes of window screen spline. This is a vinyl tube with a sort-of star profile and a hole through the middle. The hole and splines make for a squishier seal than an o-ring to conform to the glass better. Be advised that the spline is available in multiple sizes and not each home center carries all the sizes... try both Lowes and Home Depot. You want something larger than 1/8", probably the 0.142" size or larger. Buy a few different sizes. Cut strips that tuck into the back of the bezel, and try the fit. It should be a bit snug to hold the glass.
R
rnpennington
These links are the rings for the outside of the gauges - between the gauge and the dash (or I am misreading the description - also entirely possible). I was wondering about sealing the Inside of the gauges.
Thanks though - I wasn't clear which ones I was looking for
R
rnpennington
Thanks Doug - this seems to be just the information I was looking for. But I have one question - won't the carb cleaner affect the chrome?
dklawson
I have never seen carb cleaner affect chrome. Whatever they put in the dip buckets is formulated for you to soak much more reactive metals like carb bodies and linkages in. I would describe it as mild to metal and harsh on plastics, gum, and varnish.
If you want the parts to look really nice when you are done, polish the bezels with Simichrome metal polish before you reassemble the gauges. It really does a good job even on weathered bezels.
L TR2/3/3A Stupid Engine cleaning question Triumph 9
JPSmit Lever shock cleaning question Restoration & Tools 5
JPSmit final question [tonight] - cleaning transmission Spridgets 5
timbn2 question about cleaning up different metals... Austin Healey 1
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
