TR3TR6
I picked up a J-Overdrive transmission out of a 75 TR6 parts car that I want to put in my 76 TR6. I thought I better run some tests on it before I installed it. I drained the oil and put in Brad Penn GL-4 SAE 80W-90. The solenoid works just fine. I hooked up a 600psi gauge to check the pressure using my 2800 RPM half inch drill. With the solenoid engaged, I could only get the pressure up to about 310 lbs in 3rd and 4th gear; so the overdrive won't engage. Could this be caused by any of the following items; the hydraulic pump, the high pressure filter or one of the two operating pistons sticking, or something else that I need to be checking? I read the article in the Buckeye Triumphs, but the didn't say what the problem would be if the pressure was low, only that it needs to be around 450psi for the overdrive to engage.
