Stewart
If your going to go the rubber route make sure to buy the best de waxier you can find and scrub the new pieces till you think it's all gone then go another 20 minutes. Otherwise what ever glue you will use will not stick. I would recommend the 3m vinyl trim adhesive as it works really well.
To replace them your going to have to pull the seats, side and front panel and the floor cover both the front and rear to make it as easy as it can be. I believe moss makes the original rubber flooring as well but buy the time you by the replacement flooring and sill covers your a good chunk of the way to the cost of a good carpeting kit.
By the way when you do go to remove it expect to make good friends with a scraper as the rubber if it was like mine will come off in sections. It was a good 2 day job to get all of it off.
Hi Guest!
