The Quaife is a nice set-up. They are pricey with about a $1500 buy in for the TR8/Rover SD1 unit. On top of that, you will have to pay to have it installed. Last time I looked, I think they were being sold by a company out of Texas. Another alternative might be to go to a ford 8.0 or 8.8 rear end. Woody sells them, but the guy who makes them up for him isn't very reliable. Sometimes it takes months to get them back. The down fall is that they are heavier. The upside is that there are many different gear choices. They are a posi clutch type design. They are stronger, and you can get them with disc brakes. He takes a stock Ford rear end out of a t-bird tubo coupe or SVT mustang. He has them narrowed slightly, and has the correct TR mounts installed out of laser cut steel. He buys new shorter axles that have the correct bolt pattern. If you want to spend the extra money, he will even install a Willwood brake kit and a Locar e-brake set-up. The Fords come stock with rear disc that have a small drum in the center for drum style e-brake. The final price will be more than the Quaife install, but you will have a bullet proof rear end that will handle all the power you can make. You will also have to buy one of his custom driveshafts. They are an absolutely beautiful piece. They are modeled after one I had built years ago for my race car, and are not to be confused with the ones of lesser quality sold by a certain guy in Ohio. They are a Spicer unit with renewable u-joints. I have to run a stock rear in the race car, and I'm too cheap to pony up the money for one of Woody's rear ends for the street car. He has sold a couple of dozen over the years, and as fas as I know, everybody is happy with them. He has probably sold around 100 of the driveshafts. I think Tim Lanocha might make up a Chrysler rear end. I don't know if he sells them, but he has one in his car. You could look into having a local guy build one up for you. That would at least save on the shipping charges. I think the Ford rear ends can be found for around $350. I would bet you could do the rest for $1500 or so. Parts ain't cheap nomore.
