TR4/4A pvc adhesive
nbailey
Member
Could someone recommend the best adhesive for the rubber seal to the pvc transmission cover? The PO used silicone which did not stick very well. Thanks in advance.
TR4nut
It’s been a while but I think I used 3M weatherstrip adhesive, a type of contact cement.
martx-5
I second the 3M Weatherstrip Adhesive. It's tenacious stuff, and comes in black or yellow. Years ago it only came in yellow and was know as monkey snot.
Rut
Yep, monkey snot is the best and rough up the PVC with 60-80 grit sandpaper, clean with something like prepsol before and after sanding to get rid of the mould release agent.
Rut
Tybalt
We always called it "yellow gorilla snot." Regardless of what you want to call it, it will work much better than an RTV siliconized rubber in this application. Since the transmission cover has already been hit with the siliconized stuff, cleaning will be critical to form a good bondline so don't try and short cut that step, it is the most important one in the entire process of bonding under just about any circumstance but even more so given the history.
T TR2/3/3A TR3A Cloth vs. PVC Wire Harness Triumph 4
A TR6 PVC vacum Triumph 3
J MGB PVC valve on MGB 1973 MG 2
KVH TR4/4A TR4A No PVC Valve OK? Triumph 14
G Wire Wheel Question: PVC Tape Triumph 19
smaceng 1275 PVC valve spring? Spridgets 0
R engine hiss, PVC on 1500 midget Spridgets 20
RSMTR8 Wedge TR8 PVC/Flame Trap Filter Replacment Triumph 1
RSMTR8 Wedge TR8 PVC Valve Triumph 1
SpannerMan TR6 Rimmer Bros Vynide PVC Top/Hood cover TR6 Triumph 3
Bill Redd TR6 TR6 washer PVC tubing Triumph 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
R TR2/3/3A Weather strip adhesive Triumph 11
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
glemon General Tech Upholstery Adhesive Triumph 11
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
DNK Wedge Adhesive Help Triumph 5
glemon Rubber trim adhesive Restoration & Tools 5
DNK Wedge Anybody have any "good" adhesive? Triumph 2
NutmegCT Loctite weatherstrip adhesive Restoration & Tools 6
TR4A_IRS Best adhesive for PCV diaphragm? Triumph 5
Nelson "High" temperature adhesive Spridgets 7
I Adhesive suggestions? Spridgets 4
T Front Shroud Adhesive Austin Healey 10
bigjones How to use non-adhesive wiring harness tape Spridgets 2
sparkydave Adhesive for seats Spridgets 1
W Adhesive for seat padding Spridgets 1
B Adhesive for interior trim pieces? Jaguar 7
TR4nut Is there a weld-through adhesive? Restoration & Tools 22
jjbunn How to remove weatherstrip adhesive?! Triumph 18
Popeye Panel adhesive - continuing "welding for dummies" Restoration & Tools 7
MadRiver Cleaning up 3M adhesive spray? Triumph 18
Nunyas Carpet Adhesive MG 28
Shinsen774 Old Hood Liner Adhesive Removal MG 7
Ed_K Adhesive to use for the bonnet heat shield ? Austin Healey 14
L Removing Carpet Adhesive - Blast Media? Austin Healey 17
Cain Seal Adhesive Triumph 5
N Is it a grout, a filler, an adhesive or what? MG 6
J Trunk Kit Adhesive Austin Healey 3
