Is there any reliable information out there on aligning chasis and inner body pieces as you put them back together?
Rust required me to cut out inner sills, rocker panels, both front outriggers, both shut pillar assemblies and the 1/4 panel sections they were attached to, the hinge pillar assemblies as well as the parts of the wheel arch assemblies that the inner sills attached to.
I took a lot of pictures, but due to the amount of rust, I didn't think (now there's an understatement!) that any measurements I took would be valid.
The outriggers are now in place, and if I simply rest the inner sills on the outriggers, everything "seems" to line up. However, I realize that everything from that point on is dependant upon where I set the inner sills! I don't want to start attaching pillars etc. only to find that the doors won't hang properly or that I have to start tearing everything out to correct an early mistake!
I've read accounts of how pieces at the factory were "hand fit" to make up for irregularities in assembly dimensions, but I don't want to be in a position where I have to "hand fit" (tweek with a big hammer)everything from this point on!
Roscoe, in a recent post, seemed to know what he was doing, but my instinct tells me that it came from previous experience. Any help out there?
