RAC68
Hi All,
Hate to be on this side of the query but today was the day to change the oil and set the BJ8P1 up for dry winter driving. Cocooned in an unheated garage for the past 2 weeks, the Healey was difficult to start at 20-degrees F with 20w50. Once started, the engine ran well even though its temperature never got above 60-degreese. Halfway through my local run, the car sputtered and stopped.
Arriving home on a friend’s towrope, I checked the carburetor bowls and found little gas with very little sediment (no filters used). Pulling the gas line off the carburetor, I turned on the ignition and found a modest flow from the AUF301 fuel pump.
Following a quick air bench test, which seemed to indicate the pump working, I disassembled the lower section and found no dirt or clogs. Blowing out the lines from the pump to the tank and to the carburetors, I reinstalled the pump for a flow check. After a short period of pump ticking it came to a stop as if up to pressure, however, no flow was created.
At this point, I think the pump seems capable of pumping air but not fuel. Has anyone experienced this? Any suggestions would be appreciated.
Ray (64BJ8P1)
Ray (64BJ8P1)
Hi Guest!
